It is currently Fri Aug 15, 2025 6:12 pm
 Post subject: Zipflex
PostPosted: Mon Aug 24, 2015 5:07 pm
I got some of that flexible Abalone from LMI today. Man is it thin! I usually level my rosettes on the thickness sander and it looks like the Abalone is only a couple of thousands thick over the rubber backer and would be very easy to sand through if not perfectly level at installation.
Have any of you guys had that problem?
 Post subject: Re: Zipflex
PostPosted: Mon Aug 24, 2015 8:21 pm
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I really like zipflex and have had good success with it. I do inlay it as flush as possible to avoid excess sanding, but I have never had any issues with the sanding I have done. The shell component is .050" so you should be fine as long as you are careful.
It will probably be alright.
These users thanked the author Greg Maxwell for the post: LanceK (Tue Aug 25, 2015 12:09 pm)
PostPosted: Mon Aug 24, 2015 8:58 pm
Whoops I just looked closer. At first I thought it was just a thin veneer on a thick rubber backer. OK now I see. Yeah that'll work great!
Thanks!
PostPosted: Mon Aug 24, 2015 10:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Zip flex is a really cool product. Good luck!
PostPosted: Tue Aug 25, 2015 12:10 pm
I also love it and use it just as Greg said. Keep it all close as possible.
PostPosted: Tue Aug 25, 2015 2:28 pm
I don't think the shell is 50 thou .. more like 30, plus the backer plastic, unless its been changed recently ... I like to inlay it below flush, then sand down to it ... better safe than sorry.
PostPosted: Tue Aug 25, 2015 3:37 pm
I always thought the stuff was too homogenized for my taste. No broken abalone lines. Besides, a green strip of wood looks better than black next to abalone.
But, I suppose for "modern guitars"...
PostPosted: Tue Aug 25, 2015 11:22 pm
First name: Jeff
Last Name: Dillard
It's great for laying around sides
PostPosted: Tue Aug 25, 2015 11:29 pm
Well now that I've found that it is actually plenty thick I'll be using it on a rosette tomorrow and will report back.
PostPosted: Sat Aug 29, 2015 9:26 pm
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
I love the stuff.
Users browsing this forum: ballbanjos, Bing [Bot], DennisK and 10 guests
